i thaught it's time to give something back to the nice people in this forum here from which i got so much supply and informations. Thanks a lot at this point!
...so here's my personal variation of the d-lite:
It's my 5th custom built amp now, which i started by dismantling a homebrew marshall 18 watt clone, took out the transformers and other parts still useable, and put the whole stuff in a standard Hammond-Chassis. (The 18Watt Marshall-Clone was nice sounding too, but due to the amp-design, distortion only works at higher volumes. I often play at home at lower volumes, so it really wasn't the right amp for my needs. The other reason was, that i didn't have the money for completely new parts...so i sacrificed the Marshall-Clone...
) The transformers, the chassis and most of the parts, i got from a german tube-specialist "www.tubetown.de", which has a good sorted web-shop and affordable prices. The PT is a Torodial 106VA transformer, the OT is a Marshall 18 Watt/1974x.
I didn't wanted to resign the EL84's from the marshall-clone, because i really love their sound, but i also like the warmth of 6V6's, so i thought it would be a nice feature to have a switchable power stage - EL84's selfbias / 6V6 fixed bias - without the need of sticking tubes inside out.
Another point was the fx-loop. I decided to integrate the standard dumbleator with a bypass-switch to took it out if i want.
So here it is: D-Lite convertible - EL84 selfbias / 6V6 fixed bias - with integrated switchable Dumbleator.
Construction is tested and the amp works fine since 3 months now. It's a very versatile amp and good sounding too!
There's definately a tonal difference between EL84's and 6V6's and it was really worth to try this thing out. Hard to say what i like more - i like both - in every mode - clean and distorted.
Schematic, layout and some pictures of the amp you find in the attachments.
Feel free to use them, if you want.
Merry Christmas to all forum members!
George
[img
