treble caps
treble caps
What type of caps do you use for treble caps? I cant seem to get any 6PS values low enough to put there. Btw im using 330pF for the clean channel and 200pF in the OD section. I have ceramic caps in those values but im worried it will make the high end "scratchy" and "harsh"
It's true i've lost my marbles and i cant remember where i put them
Re: treble caps
Actually the ceramic grainy tone is a big part of the Dumble tone. Typically I buy several types and several of each, then just listen. I've tried silver mica and IMHO they sounded like ass in my amps but there are examples of Dumbles with SM treble and bright caps so I guess the answer is it depends.
Re: treble caps
FWIW, my ODS came with a 500 pF silver mica treble cap, which I eventually replaced with a 330 pF, silver mica too. I tried ceramic as well, but preferred the silver mica.I guess it would be best to try both types,really a matter of taste.BTW, I preferred the ceramic type for the bright switch.As usual, trust your ears, Marcos
- glasman
Re: treble caps
For what it is worth. HAD was known to use both types (ceramic and silver mica) for the treble cap, just depended on the amp and who he was building it for....
Get one of each and let your ears decide. There are many different temperature coefficents in ceramic, some sound better than others, I like NPOs. YMMV.
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Re: treble caps
Very perceptive Gary.glasman wrote:...Get one of each and let your ears decide. There are many different temperature coefficents in ceramic, some sound better than others, I like NPOs. YMMV.
Gary
I had an amp that would change / shift the tone after an hour of playing. It was attributed to the temp coefficient of the ceramic I was using. After switching from an X7R to COG(NPO) the problem went away.
- glasman
Re: treble caps
Gee, I guess in the 3 years of high school electronics, 4 years of college, 40 years of being a ham radio operator and 32 years working in the eletronics busniess I actually learned somethingBobW wrote:Very perceptive Gary.glasman wrote:...Get one of each and let your ears decide. There are many different temperature coefficents in ceramic, some sound better than others, I like NPOs. YMMV.
Gary![]()
Really not trying to be a smart a$$.
FWIW, the Y5P (as I remember) also work pretty well. Brands I have had good luck with have been Mallory and Panasonic. Not crazy about Xicons ceramic offering. For SM, CDE is the right choice.
Gary
www.glaswerks.com
www.glaswerks.com
Re: treble caps
Damn your oldglasman wrote:Gee, I guess in the 3 years of high school electronics, 4 years of college, 40 years of being a ham radio operator and 32 years working in the eletronics busniess I actually learned somethingBobW wrote:Very perceptive Gary.glasman wrote:...Get one of each and let your ears decide. There are many different temperature coefficents in ceramic, some sound better than others, I like NPOs. YMMV.
Gary![]()
I had an amp that would change / shift the tone after an hour of playing. It was attributed to the temp coefficient of the ceramic I was using. After switching from an X7R to COG(NPO) the problem went away..
Gary
jk Gary...
Looked up those caps on Mouser. They don't seem to come in all the values seen in ODS'. What else do you use?
- Funkalicousgroove
Re: treble caps
ScottL Turned me on to some great Panasonic X5F caps that seem to maintain pretty well, I've really been into Mica caps lateley though, at least for the treble.
- glasman
Re: treble caps
ChrisM wrote:Damn your oldglasman wrote:Gee, I guess in the 3 years of high school electronics, 4 years of college, 40 years of being a ham radio operator and 32 years working in the eletronics busniess I actually learned somethingBobW wrote: Very perceptive Gary.![]()
Gary![]()
jk Gary...
Yup older than dirt and twice as dusty. I will be 55 in a few weeks. Got licenced in 1969 as WN6JZS. Today it is KF7XP and I can still copy morse code in my head
I buy panasonic parts via Digikey. CDE can be had at mouser last time I checked. Sprague also makes a line of SM"s and they are not too bad as well.
www.glaswerks.com
www.glaswerks.com
- glasman
Re: treble caps
Yup, use them as well (cool yellow color), nice and seem to be pretty stable. They also sound good. Shame they don't make a 500 puffer in that series...Funkalicousgroove wrote:ScottL Turned me on to some great Panasonic X5F caps that seem to maintain pretty well, I've really been into Mica caps lateley though, at least for the treble.
www.glaswerks.com
www.glaswerks.com
Re: treble caps
Thanks everyone, the ceramic caps i got were from tubesandmore.com
labled Y5P theyre 6000V caps, seem pretty generic.
Im not sure if anyone has tried these but i am sure that my ears are very picky on the treble frequencys so i'll try a few different types.
I've heard silver mica caps dont work too well in the preamp section on D style amps, they were described as thin and buzzy when used for the V2 snubbers.
- glasman
Re: treble caps
I have tried these as well. Not very appealing to my ears.JD0x0 wrote:Thanks everyone, the ceramic caps i got were from tubesandmore.com
I only use them as treble caps. either 250, 270, 330 or 390pf ceramics for the snubbers.I've heard silver mica caps dont work too well in the preamp section on D style amps, they were described as thin and buzzy when used for the V2 snubbers.
www.glaswerks.com
www.glaswerks.com
- David Root
Polystyrene
How about polystyrene caps, as either treble or plate snubbers? I have poly OD snubbers in my Dumbleized 6SL7 amp.
Re: treble caps
No offense taken Gary,glasman wrote:Gee, I guess in the 3 years of high school electronics, 4 years of college, 40 years of being a ham radio operator and 32 years working in the eletronics busniess I actually learned somethingBobW wrote:Very perceptive Gary.glasman wrote:...Get one of each and let your ears decide. There are many different temperature coefficents in ceramic, some sound better than others, I like NPOs. YMMV.
Gary![]()
Gary
