Thoughts on replacing slope resistor with a pot.
JD0x0
Post by JD0x0 »
Anyone have thoughts on replacing the slope resistor on my OTS, or any other amp for that matter, to a 250K pot.
It seems like a simple mod that should be standard on all amps. It's so simple yet it does so much. The amp would be tunable from a "flat," bass heavy tone, to a more trebly scooped tone and everything in between is possible by the turn of a knob. not to mention it affects the other tone controls for more flexability.
My question is how come no one seems to be doing this? I mean in theory it would turn a normal blackface fender into a "poor mans marshall" by turning the pot to a lower value which would increase midrange and bass.
Just one of my crazy amp mod ideas :D
It's true i've lost my marbles and i cant remember where i put them
Bob-I
Re: Thoughts on replacing slope resistor with a pot.
Post by Bob-I »
A friend of mine did that on one of this Plexi style amps. He used a 47K slope resistor and a 100K pot. He said that going to 0 on the slope pot cause all kinda of problems including oscillation.
JD0x0
Post by JD0x0 »
Bob-I wrote:A friend of mine did that on one of this Plexi style amps. He used a 47K slope resistor and a 100K pot. He said that going to 0 on the slope pot cause all kinda of problems including oscillation.
So im assuming as long as it stays above "0" or very low settings it okay?
dave g
Post by dave g »
I have seen this done before a few places. I think all the old Heritage amps had this standard.
Yeah, you don't want the slope resistor going to 0. Put a 22k in series with the pot.
ayan
Post by ayan »
JD0x0 wrote:Anyone have thoughts on replacing the slope resistor on my OTS, or any other amp for that matter, to a 250K pot.
Be careful. Unless you put a coupling cap after the preceding stage, you will have one hot pot there.
Gil
odourboy
Post by odourboy »
Gil
Sounds scary but 24mm Alpha linear pots are rated at 500V and PEC pots even higher.
ayan
Post by ayan »
odourboy wrote:
Gil
I appreciate that. Still, I would be careful about turning the metal shaft when one of the lugs is hot. :)
G.
j-po
Post by j-po »
So what if the pot shorts to ground? B voltage through the plate resistor to ground. Nothing dangerous about that. Of course if it were to short to an ungrounded pot shaft you might be in trouble.
odourboy
Post by odourboy »
Not much different than a toggle switch with 450V of standby or 120VAC just under that metal shaft if you think about it. :shock: (I try not to think about it! :D )
j-po
Post by j-po »
odourboy wrote:Not much different than a toggle switch with 450V of standby or 120VAC just under that metal shaft if you think about it. :shock: (I try not to think about it! :D )
With the exception of that plate resistor limiting current.
ukulele
Post by ukulele »
We is no corrupt in government of Soviet Finland. It is being legal to bribe politician. Country very niiice.
Bob-I
Post by Bob-I »
ayan wrote:Be careful. Unless you put a coupling cap after the preceding stage, you will have one hot pot there.
Gil
Oops, I didn't think of that. Beyond a hot pot, you'll also be changing the plate loading. I'd say the coupling cap is a necessity.
dave g
Post by dave g »
Bob-I wrote: Oops, I didn't think of that. Beyond a hot pot, you'll also be changing the plate loading. I'd say the coupling cap is a necessity.
A coupling cap isn't going to prevent the loading, that's not how it works...there is no DC path to ground at the input of the tonestack anyway.
briane
Post by briane »
for a personal amp its a fine idea. If its going on the road, in general less knobs is better. More knobs, more things for a tech to fiddle with, more things to go wrong.
One also has to wonder about the quality of the resistive material if you put a pot in there. Will you be getting RN65 smoothness and quitetude? We can surmise the answer is no.
butwhatif
Post by butwhatif »
pots go bad over time, esp w hi voltage on them. even a new pot leaks dc
