Tranny help...again
Tonegeek
Tranny help...again
Post by Tonegeek »
I am thinking of biting the bullet and buying a MM tranny for a friend build, just to see for myself what all the hooplah is about. I was thinking on getting this one: FBFBM-OM which is a Toneclone Bassman 4-8-16. Anybody see an issue with that? Also, does anyone know of a standup PT that would have a bias tap and Bassman voltages? I got to order this stuff by Monday. I have had good luck with the 50 watt Mag Components Marshall trannies from AES, but miss the bias tap. OTOH, I can run EL-34's with the MC if needed...
thanks
Pitcher Amplification
http://pitcheramps.com
tubedogsmith
Re: Tranny help...again
Post by tubedogsmith »
Heyboer will make you anything you want. I get one off's from them all the time.
sergio
Post by sergio »
have you never thought about fender original trafo?.
Sergio
odourboy
Post by odourboy »
Tonegeek wrote:I am thinking of biting the bullet and buying a MM tranny for a friend build, just to see for myself what all the hooplah is about. I was thinking on getting this one: FBFBM-OM which is a Toneclone Bassman 4-8-16. Anybody see an issue with that? Also, does anyone know of a standup PT that would have a bias tap and Bassman voltages? I got to order this stuff by Monday. I have had good luck with the 50 watt Mag Components Marshall trannies from AES, but miss the bias tap. OTOH, I can run EL-34's with the MC if needed...
thanks
I'm very curious about trying a MM OT as well, so I'll be watching this one!
FWIW, I used the MC PT and OT from AES as well for my last 50W BM build (funny how we keep running into each other Tonegeek! :D ) and I'm pretty happy with it.
Guitarman18
Post by Guitarman18 »
Hi Tonegeek,
MM will also supply their trannies in all the common mounting formats.
Look in the FAQ's section and at the bottom of the list is:
http://www.mercurymagnetics.com/pages/n ... Mounts.htm
Hope this helps.
Cheers, Paul.
Tonegeek
Post by Tonegeek »
Guitarman18 wrote:Hi Tonegeek,
Hope this helps.
Cheers, Paul.
Thanks for reminding me about that. will factor into my decision.
Tonegeek
Post by Tonegeek »
thanks
Yes we do. I thought when i joined AG, I might build one amp (just out of necessity to get better tone) and then I would be out of here, but funny how it draws you in for more. I am l kind of a binge drinker with this place. I hit it hard for a while (especially when I am building something) then back off. Its been really interesting here lately and I do like seeing the familiar crowd as well as the newcomers.
I will let you know what trannies I settle on.
