I plan to try:
1. swapping out pre and PI tubes
2. It could be a heat related issue, in particular, the 2 paralleled 6.8K 5W resistors (choke resistors).
3. Measuring the B+ voltages, Plates and screens every 10 mins. looking for a delta measurements.
4. Using a sine wave input, dummy load (4 Ohm), in 100W OD mode.
5. makeshift a cover to let the heat buildup.
6. re-inspect / resolder suspect joints.
The 2 thiele cabs used that evening, 1 EVM 12S, and 1 EVM 12L were tested and are not suspect. I forgot to mention this is a #124 build with about 30 hours total time. The present tube complement consists of JJs for the preamp and Winged Cs for the outputs. Other than this issue, the amp sounds wonderful.
My usual settings are:
Vol 2,3
Bright, Mid, Rock On
Treble 5,6
Mid 5,6
Bass 5,6
Drive 4
Level 6
MVol 7
Presence 6
Any comments welcomed
