Bludotone Ford tone
dogears
Bludotone Ford tone
Post by dogears »
http://www.scottlernermusic.com/rf/Blud ... eRFMod.mp3
Here is a clip of my Bludo High Voltage Music Man 6L6 amp running a Glaswerks Matchbox in the loop. Slight verb and delay in there.
My friend Steve Lipinski (pinner) was playing his Collings.
Recording is just a hand held Sony PCM D50 digital flash recorder a bit off axis.
Glaswerks 2X12 cab with new Heritage G1265 speakers. Speakers are brand new.
We also recorded a clip of me Fuchs 75 mod with the same exact circuit. It is basically rewired and has a built in Dumbleator. Hence, I was not running external loop, but internal. However, my loop has cable simulation designed in.
http://www.scottlernermusic.com/rf/Fuchs75RFMod.mp3
The biggest difference is in how the different trannies saturate and the basic tonality difference of the 6L6 tubes since one runs them at 670 or so.
Thanks to Steve Lipinski for his great playing!
Bob-I
Re: Bludotone Ford tone
Post by Bob-I »
Sounds great, but I was expecting something a bit different. I was expecting more singing harmonics and less mud in the bass end. I don't really hear anything different from an unmodded amp.
dogears
Post by dogears »
They are totally different. Trust me..... I have had enough unmoddeds. I was standing about 45 degrees off axis with the handheld.
Bob-I wrote:Sounds great, but I was expecting something a bit different. I was expecting more singing harmonics and less mud in the bass end. I don't really hear anything different from an unmodded amp.
Bob-I
Post by Bob-I »
I'll bet you need to be there to really hear it. Clips don't do justice to subtleties of tone.
Guitarman18
Post by Guitarman18 »
Thanks for sharing these Scott, I've often wondered if I should go for MM iron with high voltage. To my ear the Bludo/MM gives the notes extra 'dimension' (for want of a better word) and the top end seems to have more refinement, which is something that I struggled to achieve with my lower voltage BM and high plate amps. Certainly qualities that I hear in RF's tone.
Having said that, I thought it had been deduced at one time that RF had regular Twin iron in at least one of his amps?
To clarify, is the Bludo a BM preamp with non HRM?
Cheers, Paul.
mlp-mx6
Post by mlp-mx6 »
I prefer the Bludo to the Fuchs in this example, especially as it relates to RF tone. There is a "hollow thickness" to the mids - don't know exactly how to describe it - that is very reminiscent of RF in the first clip. The pick attack and "bloom" or "swell" sounds spot-on as well.
Inspiring tone!
Me: Just one more...
mcinku
Post by mcinku »
Bludo sounds a little better for me as well. Fuchs is almost dull sounding compared to Buldo.
What kind of tubes did you use? ...same tubes in both amps
bluesfendermanblues
Post by bluesfendermanblues »
dogears wrote:http://www.scottlernermusic.com/rf/Blud ... eRFMod.mp3
What exactly is the RFMod - the 300 ohms resistor replaceing the choke??
heisthl
Post by heisthl »
Great playing and tone Scott 8) :)
www.RedPlateAmps.com
dogears
Post by dogears »
Thanks!! That was "pinner" playing. He knows a whole bunch of RF tunes so he was a great demo guy!
heisthl wrote:Great playing and tone Scott 8) :)
Funkalicousgroove
Post by Funkalicousgroove »
Both of robbens amps have chokes.
bluesfendermanblues
Ok, can you give a hint ? :wink:
stelligan
Post by stelligan »
Music Man iron sounds stellar! 8)
odourboy
Post by odourboy »
Wow - the Bludo sounds fat! 8) Is it a BM?
Funkalicousgroove
Skyline EQ Standard OD.
