Josh Smith Jamming on a Bludotone
- Funkalicousgroove
Re: Josh Smith Jamming on a Bludotone
Sounds good Brandon.
Do you know what guitar he used?
larsmuller
This just blew me away....sjeeezzz what a nice sound...so HRM or not?? Bluesmaster??? Guitar??
I like your amps !
I like your amps !
Taming a bluesmaster HRM,...
Sounds GREAT.
Josh can rip, there's no doubt about it. And he's a nice guy to boot!
T. Jauernig
- Funkalicousgroove
Josh is an awesome guy, it's nice to meet talented people that aren't all full of themselves.
- Funkalicousgroove
He's either playing a tele or a les paul, the amp is a Classic with standard overdrive, it's the same amp that court was using on Jay leno the other night-larsmuller wrote:This just blew me away....sjeeezzz what a nice sound...so HRM or not?? Bluesmaster??? Guitar??
I like your amps !
tubedogsmith
Brandon, is this a full classic with 100k plates? Any treble bleed anywhere?
Funkalicousgroove wrote:He's either playing a tele or a les paul, the amp is a Classic with standard overdrive, it's the same amp that court was using on Jay leno the other night-larsmuller wrote:This just blew me away....sjeeezzz what a nice sound...so HRM or not?? Bluesmaster??? Guitar??
I like your amps !
Great sounding amp - killer player.
It seems you can tell when a player is digging the sound he has going. Sounds like he had a blast with the amp. Congrats! Does he own this one then? Or trying it on for size?
- Funkalicousgroove
it's his amp, I built it to his spec- he just let Court borrow it for TV until I am done with his
It's actually a High plate classic, the low plate classic is very bright IMHO- Cool, but bright.
tubedogsmith
Thanks, that's what I thought. The tones he's getting didn't sound like 100k plates unless you had some kinda kickass treble bleed in there.Funkalicousgroove wrote:it's his amp, I built it to his spec- he just let Court borrow it for TV until I am done with his![]()
tubedogsmith wrote:Simply impossible to to say from a recording. Also, the effect of the guitar tone control being rolled off some can be greater than that of the plate load resistor values, or even using a 4x12 closed back VS 1x12 open back, etc. I have seen Josh play live a couple of times -- fantastic player! -- and he seems to consistently gravitate towards that nice fat type of tone, so it makes sense to me that he'd sound like that regardless of amp and guitar.Funkalicousgroove wrote: Thanks, that's what I thought. The tones he's getting didn't sound like 100k plates unless you had some kinda kickass treble bleed in there.
(Very cool clips, Josh!)
Gil
tubedogsmith
I don't disagree but it didn't sound like a 100k plate amp to me and I was just checking to see if something else might have been going on. It's hard to tell on recordings but it sounded like a bridge pickup and didn't sound like what I hear with the low plates. Besides, who wants to play their new amp with the tone control on their guitar all the way down! The distortion seems a little different between the two but i certainly defer to your greater experience with these things.
Ah, Tubedogsmith... I am a tone control knob snob too.tubedogsmith wrote:I don't disagree but it didn't sound like a 100k plate amp to me and I was just checking to see if something else might have been going on. It's hard to tell on recordings but it sounded like a bridge pickup and didn't sound like what I hear with the low plates. Besides, who wants to play their new amp with the tone control on their guitar all the way down! The distortion seems a little different between the two but i certainly defer to your greater experience with these things.
If I had to guess, I would think that on that clip Josh either has the tone control on the guitar slightly rolled off, or else he is not using PAB at all and has the tone rolled off from the amp (by which I mean below 12 o'clock when using linear pots, or below 2+ o'clock when using audio pots)... However, I have to confess that the compression factor (again, impossible to tell from a recording, especially one tha thas been encoded as an MP3) would suggest to me that hehad the PAB on. Maybe Josh will chime in and take me out of my mysery.
In closing, if I had been asked to guess I would have thought the amp was a Skyliner because of the fatness and pretty significant bass I hear, and I would have been wrong. That's what my "greater" experience does for me.
Gil
