I filleted a non working 2-6L6 Blues DeVille and I need help in the color code
wiring for the PT/OT. I looked at the Schematic Heaven's factory schematic but I can't decipher it .(being the newb that I am and extra import wires) Any help would be very much appreciated! Thanks, Andrew
Fender 2-6L6 Blues Deville
bluesfendermanblues
Re: Fender 2-6L6 Blues Deville
The primary side should be
blue red (center) brown
the secundary side (speaker connection)
green (hot) black (Ground)
Disclaimer: If you're a Newb you got to know that you're dealing with lethal voltages here!!!!!
And connecting the OT wrong could be a fatal mistake - so perhaps leave it to a pro!!
The only PT/OTs that I am familiar with are Hammond and Weber transformers. I have built many amps from scratch using their transformers but when confronted with a different brand (FENDER)
I take MUCH caution!
Here is the Hot Rod Deluxe schematic which has the color codes for the transformers. This file is very easy to read.
From looking at this drawing I think the taps for 120v primary would be the Black and Black/Yellow wires. Hook them up and see what voltages you get on secondary, aim at 340v-350v (maybe higher) on B+. 6.3v for filaments (maybe slightly higher).
Converted a 4-10 a while ago and was impressed with tone from the Fender iron.
