Where are the resistors? (70's power supply)
ic-racer
Post by ic-racer »
Can't seem to locate the position of the parallel bleed resistors on first two capacitors. Does anyone know where they are (are they between the capacitors?). Perhaps there are none??
ic-racer
Re: Where are the resistors? (70's power supply)
Post by ic-racer »
Ok, I may be answering my question. I just found this shot of a Winterland and it shows the two resistors BETWEEN the capacitors. Perhaps that is what is going on with the silverface, 70's ODS amps?
LooseChange
Post by LooseChange »
The first two caps may not have resistors because they are in series. The two caps are 100uf @ 350v (that's what I can see). In series they are 50uf @700v. Perfect for the B+ position in the power supply. Many will parallel a resistor to the caps to distribute the load. I don't see them.
