Presence Control
Presence Control
Does anyone have a part number for the 1.0uF presence cap that fits a Funk board?
Karl Fridrik
bluesfendermanblues
Re: Presence Control
What is the funk board?
I have a bord set that I bought from Funk.bluesfendermanblues wrote:What is the funk board?
Karl Fridrik
Is it particularly hard to fit a cap on those boards? Any 1.0uF film cap should work fine...doesn't even have real voltage on it in that slot.
-g
- glasman
Usually it is a 1.0uf electrolytic. The 35 or 50V ones should fit.
Dumble also used 1.0uf tantalum on some amps. If you are building a bluesmaster you want a .1u poly cap in that position.
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
I use a 1uf radial cap 35v and bend the leads out, for the BM PI I use a NTE .1uf @ 250v
I've used mouser 5989-100V1.0-F, which is a CDE type DME 1uF, 100V polyester film. Seems fine, but I'm not the same class as Funk and glasman. I'm probably more the cottonears type.
Ditto http://www.mouser.com/Search/ProductDet ... -100V1.0-Fjaysg wrote:I've used mouser 5989-100V1.0-F, which is a CDE type DME 1uF, 100V polyester film. Seems fine, but I'm not the same class as Funk and glasman. I'm probably more the cottonears type.
They work great.
www.RedPlateAmps.com
- glasman
Ain't nothing fancy about my presence caps.
For 1's it is either Xicon or Nichicon
For .1uf I use Xicon MPP's (trying to deplete stock).
Gary
Gary
www.glaswerks.com
www.glaswerks.com
Honestly I like a .68uF cap there. The 1uF presence control seems to be a tad harsh in the upper mids. I tried a .68 and love it. Less brightness from the presence, but more pleasing.
