Data Collating?
Data Collating?
I was wondering if it would be possible to catagorize the Dumble schematics and layouts into stickies for the various model amps, like in the Trainwreck files section.
Whoever did that in the wreck page is to be commended! :D
Sometimes it's very confusing to sort through the various versions and nomaclature concerning the different circuits.
Because in the threads people will refer to the HRM, Bluesmaster, #124, etc. then you have to figure out which schemo to look at.
Sorry if this is a lame suggestion.
If I had the capability I would volunteer to do it but I don't.
ic-racer
Re: Data Collating?
Post by ic-racer »
Oh yea! I just looked over at that and we are certainly the poorer child without those stickeys.
Just off the top of my head I think the popular builds are
D'Lite
#124
General NonHRM
General HRM
HRM/Bluesmaster
Dumblator
Moderator, it would be great to have:
D'lite Files
#40 Files
#124 Files
General Non-HRM Files
General HRM Files
HRM/BLUESMASTER Files
Steel String Singer Files
Dumblator Files
joebob
Re: Data Collating?
Post by joebob »
I was looking at the #124 schematic labeled 'version 2.7 5/12/08' and comparing it to the version by odourboy 'rev.1.7 03/06/08'. I saw a difference in the PAB relays, one shows 'NO' not connected and the other show 'NC' not connected, which is correct? I was also comparing it to the 50w layout on 'SchematicHeaven' and there are relay errors. The relay pin numbers don't seem to go with the layout or schematic.
Also the V1A and V1B pin numbers are reversed, also the PI V3A and V3B are reversed as well. On V1a pin 2 goes to the Normal jack not pin 7. On v3a pin 2 goes to the .05 uf cap not pin 7.
Dave
Instructions...I don't need no stinkin instructions
heisthl
Re: Data Collating?
Post by heisthl »
The tube pin number difference is because of orientation, it is theorectically quieter to cascade the tube using the pin 7 grid stage feeding the pin 2 grid stage, and you see some of the "real" McCoy's wired that way.
Relay confusion - NC is generally accepted to be "not connected" or "no connection" except when you are referring to switches or relays then it means "Normally Closed" and the NO means "Normally Open".
EDIT - never mind, I misread the post, the correct way to wire a relay is to decide how you want it when the relay supply fails. I want the OD and PAB to be off if there was a loss of relay power.
www.RedPlateAmps.com
ic-racer
Re: Data Collating?
Post by ic-racer »
joebob wrote:I was looking at the #124 schematic labeled 'version 2.7 5/12/08' and comparing it to the version by odourboy 'rev.1.7 03/06/08'. I saw a difference in the PAB relays, one shows 'NO' not connected and the other show 'NC' not connected, which is correct? I was also comparing it to the 50w layout on 'SchematicHeaven' and there are relay errors. The relay pin numbers don't seem to go with the layout or schematic.
Dave
The most accurate #124 schematic I know of is this one : https://tubeamparchive.com/files/124_schematic_777.pdf
I use "NC" to denote No Connection.
The relays in that schematic are supposed produce PAB and OD when the coils are energized (and thus work with any standard-wired Dumble foot pedal). The part number for the relay is given in the schematic, but the part is no longer produced.
The tube socket wiring in that schematic correctly represents the tube-socket orientation that is shown in the pictures of #124.
Realize that each Dumble is different :) They are not all like #124!
