I've seen the two 100 ohm resistors across the 6.3v to stop hum but how do you wire that up if you do have a ct for the 6.3? Does the ct get grounded and the 100 ohm resistors go to it?
Rut
Heater hum balancing question
- UltraHookedOnPhonix
Re: Heater hum balancing question
I had the exact same question in this thread:
https://tubeamparchive.com/viewtopic.php?t=5420
Hope it helps!
Hope it helps!
