From Howard Dumble Amp Wizard
"Well, the Phoenix series is where I've done that--so you can combine things--because it's a rack-mounted affair. You can by all the separate preamps, with or without overdrive, and a choice of 50-, 100-, or 150-watt power amplifiers, and hook them together. The overdrive section is expanded--instead of two overdrive controls, you have four."
What happened to these?  Any schematics?  Did Dumble ever make all of the different pre's with and without overdrive?
						Phoenix Rackmount
Re: Phoenix Rackmount
sounds like a switching network or a multiplexer. So is it series or parallel (or both)?
Might go into the loop in order to stack preamp sections. If it is series though the gain would be pretty high.
My understanding is it was not all that complex, but this is secondhand knowledge.
basically just a rack mount pre-amp, and rack mount power amp. hook the 2 together. What I think the marketing mojo is, is that any of these pre's could be hooked up to any power. Its just a method of making the different sections into components. Its a bit more versatile when joe blow shows up asking for 100 watts, and all you have to demo is 50 watters. I've been thinking about doing this myself.
Damn though, I cant believe HAD used the name phoenix, I was going to use that name for something. Guess I need a new cosmic event for the name.....
