parallel cap and resistor passive loop
sergio
Post by sergio »
What is the function of resistor(220k) and cap(250pf) in parallel?
If jack don't connected , the signal pass in through their , is not better if the signal go directly to PI after master pot?
Thank
www.sae-audio.it
Handmade tube amplifiers inspired to Dumble sound!
Funkalicousgroove
Re: parallel cap and resistor passive loop
Post by Funkalicousgroove »
It's a filter, it's only in place when the loop is not connected.
Methinks it's for use with ES335/Les paul and other generally bass heavy guitars to keep them from "Flubbing" . JMHO.
Bob-I
Post by Bob-I »
sergio wrote:What is the function of resistor(220k) and cap(250pf) in parallel?
Thank
I've never used this setup. I've just connected directly.
ic-racer
Post by ic-racer »
sergio wrote: is not better if the signal go directly to PI after master pot?
Thank
I think it is a question of HAD tailoring each amp to the buyers taste/guitar/technique.
I think this picture was originally posted by Funk, it shows a mid-80s blackface ODS (SN not given) with the older style power capacitors (like #124) and it does NOT have the filter capacitor and resistor on the send-return jacks.
