Compression
rutledj
Compression
Post by rutledj »
I've noticed that when I plug in my strat that there appears to be a lot of compression, almost as if the guitar is played through a compression pedal on low settings. I don't notice this with my semi-hollow body.
Is this normal?
Rut
phsyconoodler
Re: Compression
Post by phsyconoodler »
I notice with my strat that chords sound a little muted,(compressed?) and when you dig in the single notes bloom really nicely.That's on the clean channel.Is that what you mean?
Re: Compression
So are we talking Dumble clones here?
What circuit?
Usually sag or compression is associated with tube rectification.
And being that the Dumble's use SS rectifiers I wonder how much the choke or choke resistor affects this?
rutledj
Re: Compression
Post by rutledj »
Yes. This is a non hrm ckt. And yes, I notice it more with chords than notes.
Rut
phsyconoodler
Re: Compression
If you want Fender chime,just max out the presence.If it's too bright back off on the treble.It works.
tsl602000
Re: Compression
Post by tsl602000 »
Rut,
That's right. With a strat you have this compressed sound. With my ODS I had way too much compression. Make sure you have the cathode resistors on V1 correct. I had a "wrong" value and on my ODS clone it made my guitar sound extremely compressed.
Structo,
We're talking 'bout a different kind of compression here.
rutledj
Re: Compression
Post by rutledj »
OK. So it is normal. It's not that it is bad sounding, just different.
Thanks,
Rut
greiswig
Re: Compression
Post by greiswig »
You might also try a set of KT77's instead of 6L6's. There is still a long tail to the compression, but the initial "hit" of a pick on a string is a little firmer with KT77's IMHO. It has the effect of making your chordings and notes more immediate.
-g
