mid control -> not much control
rutledj
Post by rutledj »
I realized I had my bass pot wired incorrectly ( had too much bass). After correcting that I see that my Mid control has very little control.
My ckt is the standard non-hrm with a 250kA mid pot. Is this normal?
I tried setting up a "Voice" switch that would switch between two different mid caps (.01 and .05) but that yields virtually no tone diff either.
Rut
phsyconoodler
Re: mid control -> not much control
Post by phsyconoodler »
It is likely your mid pot is incorrectly wired also.My stock D'Lite mid control has a huge mid sweep when turned.
rutledj
Post by rutledj »
Well, It goes directly from the 150k slope resister through a .01 cap and then directly to terminals 1&2 of the mid pot. Terminal 3 is grounded.
I don't see any other way to wire it up??
Rut
phsyconoodler
It may not be the mid pot but something else in the tone stack.Tunnel vision can make you look right at something for a long time and not see what you are doing wrong.
A picture would help.
dogears
Post by dogears »
If your slope is a 15K and not 150K, that could do it!
Fwiw, the .05uf cap should have a wah like response when you cycle the mids.
The .01uf is much less so. I has very little effect on the low low mids. It boosts a bit below 1K when cranked.
phsyconoodler
His may look like this one.??
