http://reviews.harmony-central.com/revi ... +Head/10/1
This guy claims to own #3 and #4 (though I think #3 sold on eBay some time ago).This amp was the result of a conversation I had with Howard Dumble in 1968. At that time I was playing bass through a Sunn 200S with a 2 15" cabinet. Dumble asked me whay I chose the Sunn. I told him I had seen Jack Casady play through one at Winterland in San Francisco with the Jefferson Airplane and liked the sound. A month later, Dumble delivered two heads. They were labeled "Winterland" and were amps #3 and #4. He said to me" Iguess you'll beable to fill up Winterland now". The amp had 4 KT88 tubes witha Dynaco transformer and put out 220 watts at 8 ohms. It was loud enough. The amp was a single channel the volume, treble, bass and two boost swithes for treble and bass.
This sort of suggests to me that the preamp at least must follow the Sunn 200s; volume, treble, bass, low boost and high boost.
However, the 200s uses one 12ax7, and a 6an8. I see three noval tubes in the shots on here. I could see dumping the 6an8 and going to a LPT, and it looks like V3 is set up as a LTP, but I'm still mystified about the other preamp tube.
The filtering looks to be similar to the Sunn. The Sunn used 30uf 525V before the choke, HAD uses series 60uf 350V. Following the choke, Sunn has three 20uf filter stages. Though there seems to be some other filtering added on the other side of the chassis.
The Sunn was tube rectified, Winterland uses silicon.
Man, wish these pics were just a little higher resolution, or that my eyes were better.
