150W Dumble Overdrive Special for sale on Ebay
DaveBo32
Post by DaveBo32 »
Guys,
Have you seen the Dumble on Ebay? I wish I could look inside. Man, that would be a fun build.
http://cgi.ebay.com/Dumble-Overdrive-Sp ... dZViewItem
Normster
Re: 150W Dumble Overdrive Special for sale on Ebay
Post by Normster »
I've never seen pictures of this amp before. There are some very cool features implemented. Thanks for posting the link!
benoit
Post by benoit »
I actually DID see this somewhere recently, I think on the 'bay. Not too long ago. Anyone else remember seeing it?
El_Martin
Post by El_Martin »
Yep. And looked up the sellers homepage.
Month ago? dunno...
Ciao
Martin
DaveBo32
Post by DaveBo32 »
Well here is another one overseas....
Are these the real deals? I can't get over the bids these amos are getting.
tele_player
Post by tele_player »
That one has a 'Buy It Now' of only $25K. Much cheaper than Lindley's amps. I better move some money into my PayPal account.
(no, I'm not serious!)
ElectronAvalanche
Post by ElectronAvalanche »
I wonder if the current owner of the 150W ODS is lurking on this page or maybe his tech.
Are you here Mr. A. K.?
He could bring a plethora of knowledge to this group.
Electron
chris_sanford
Post by chris_sanford »
benoit wrote:I actually DID see this somewhere recently, I think on the 'bay. Not too long ago. Anyone else remember seeing it?
Better pics of that amp are posted here:
http://www.ten-guitars.de/gallery.php?g=29&si=3
chris
Ed de Jager
Post by Ed de Jager »
I would like to know more about:
(quote)The overdrive section of the preamp is very sophisticated. The overdrive tube is a 7247 and not a 7025 as usual. This amplifier has four (staggered) pots to control the Overdrive: trigger (silver ring in the "level" location), taper (Marshall-like knob in the "level" location), level (silver ring in the "ratio" location), and ratio (Marshall-like knob in the "ratio" location).
Trigger adjusts how much of the scale of signal is fed into one triode of the overdrive tube. Level adjusts how much of the signal is fed into the other triode of the overdrive tube. Taper adjusts the scale of high frequencies in the overdrive section. Ratio adjusts how much of the overdrive circuit's signals is fed back into the preamp circuit.
Especially because the Overdrive tube is a 7247 (two different triodes with different characteristics in one tube) these four pots provide an extremely useful control of the harmonic content in order to fine-tune the overdrive circuit's voicing. (end of quote)
But then again,who doesn`t.I think i have red something like that before on a production amp but can`t remember which one that was.
heisthl
Post by heisthl »
trigger= normally internal trim mounted externally?
taper= treble bleeder at top of Ratio pot?
www.RedPlateAmps.com
jelle
Post by jelle »
Heistl, it can also be the HRM treble trimmer....
JimiB
Post by JimiB »
what do you suppose that chassis was originally?
Funkalicousgroove
Post by Funkalicousgroove »
2 pcs of U channel, a piece of flat aluminum and 2 pieces of mahogany :D
JimiB
Post by JimiB »
you one funny guy! :lol:
