Vibrodriverb or vibroverbdrive special, strange name first and second, let be first then.
 Empty cab i had 6 years waiting for something, collecting the dust..Idea was to make some combo with neodimium speaker, 1x12" or 1x15", Fender style. Vibroverbs are very expensive and i like SRV sound..So vibroverb like guideline.
To make project more complicate, vibrato will be out from standard layout, to be deployed with LND150 and relay to make some better layout and avoid noise ("thump-thump").
Maybe AB2 driver for power tubes with 12BH7, 5678 , 6CG7 or some other powerful dual triodes, i will se what my eyes will see and hand grab first. Also interstage is option too, i have also one waiting for that.
To be added also Dumble overdrive stage and tone stack.
 Will be vibrato and heavy overdrive.
  Will be vibrato and heavy overdrive.Output transformer, and reverb trafo will be DIY, made for some of tanks what is also only collecting the dust. Power transformer i have from some other project.
Speakers waiting to be used JBL D130F or some modern Neo Jensen. Many parts waiting to be used, time to start some assembly!
 at the end you realize this is not a transformer (although is working like transformer) this is mechanical filter! main factors are L primary inductance, Lp parasite inductance, and Cp parasite capacitance. they are defining your sound with core laminate material too. and are mechanical variables,  L depends of primary turns, Lp parasite is pure geometry+number of turns, and parasite capacitance is number of turns and interleaving.
