Rock/Jazz
Rock/Jazz
I’ve been looking at the ODS in all its variety. I wonder what the value is of the Rock/Jazz switch. I’ve not found a good video that shows the Jazz setting in a favorable, usable light, but can’t vouch for the accuracy of the audio/video. It just sounds like a low-gain setting. Anyone here like the option of Jazz mode, or do you hardwire it in Rock? I know some who do…
Just plug it in, man.
- Colossal
Re: Rock/Jazz
You already know my opinion, but, as April Wine said..."I like to Rock"
Re: Rock/Jazz
i was thinging like you, but! i have found many good settings!ViperDoc wrote: ↑Wed Jul 06, 2022 7:31 pm I’ve been looking at the ODS in all its variety. I wonder what the value is of the Rock/Jazz switch. I’ve not found a good video that shows the Jazz setting in a favorable, usable light, but can’t vouch for the accuracy of the audio/video. It just sounds like a low-gain setting. Anyone here like the option of Jazz mode, or do you hardwire it in Rock? I know some who do…
first open more first volume to add pre-gain to OD section,
then open totally OD gain, or how you like it! it is different but stil good!
im using it when i change the speaker (which is new, and has more highs, during break in period).
also Jazz shines for slide guitar, there is no any better drive to my ears..
Re: Rock/Jazz
For myself,
The Jazz Position is more than a low setting: it's (too ) a different Equalization.
I use it a lot with a Semi-Hollow ( a PRS Hollowbody I with Jim Wagner Crossroad pickups) and I get a bunch of Larry Carlton style sounds for example , jazz (!
) sounds
Re: Rock/Jazz
Jazz setting very useful for small spaces!
Re: Rock/Jazz
VERY GOOD. I've never built one of these, but will take the plunge in the next few months. I'm thinking ODS clean only/Small Special derivative. I have an ODS clone that has a very shrill overdrive. Not sure if that's fair for all ODS overdrive circuits. But if Robben Ford only uses the clean, and looking at all the boost pedals I have here in the garage, well, a clean ODS might just make some sense. Sacrilege aside, putting a real tube, clean overdrive in the loop could get you somewhat close, so long as it's not noisy, right?
Re: Rock/Jazz
Re: Rock/Jazz
WOW. Thanks for the clip, Tony.
I'm going to assume that was a proverbial "No Overdrive? [EDIT: AND Jazz mode!] Hold my beer..." post. NOTED.
WOW.
What am I supposed to do now?... ...
Re: Rock/Jazz
I've only had a 183 build up an running for a really short time, and far from optimized at that, but the overdrive is not shrill at all.
Re: Rock/Jazz
I also find myself mostly in Rock mode but I did find an interesting setting I like in Jazz. If I hit the pre amp boost switch in Jazz mode when i am in the clean channel the amp has a really nice round and smooth sound happening. The boost is very intense when in Jazz mode too.
Cheers
Guy
Cheers
Guy
