ODR #072 on Reverb
ijedouglas
ODR #072 on Reverb
Post by ijedouglas »
Ian
Aaron
Re: ODR #072 on Reverb
Post by Aaron »
Beautiful amp. Hopefully we get to hear it one day.
Aaron
Guy77
Post by Guy77 »
Interesting how it has no extra knobs in the back to adjust the Overdrive and the separate clean mix knob like the #60 has.
This looks like it would have a different preamp circuit than the #60
Cheers
Guy
fred.violleau
Post by fred.violleau »
Owner says "I have owned the amp for about 20 years now - only played in the house." and lists another Dumble for sale on reverb... Really curious as to whom collects amps like these only to play them at home. Need a big property to handle the volume of two beast like these :lol:
Fred.
mojotom
Post by mojotom »
Guy77 wrote: Thu Nov 04, 2021 12:11 pm Interesting how it has no extra knobs in the back to adjust the Overdrive and the separate clean mix knob like the #60 has.
Cheers
Guy
I think most of them are unique regarding circuit topology (from the start and with tweaking from him).
#60 was heavily tweaked and some ODSR have a separate Rev Level for each channels.
Most of the Silver chassis may have started life as Pre OD. This one could be still a Pre OD Reverb.
Guy77
Post by Guy77 »
mojotom wrote: Sat Nov 06, 2021 12:38 pm
Cheers
Guy
Hi Tom. Yes I agree. I attached a close up pic of the back of the amp with arrows showing the empty preamp tube positions. There appears to be only 2 preamp tubes in line across the back were as the #60 had all 6 tubes straight across the back.
If one looks more closely at the back shots you can make out another tube further back in the chassis. So this one has them spread out across the chassis much like the Steel String Singer #5 and #2.
I wonder how many preamp tubes this one has? Interesting!
Guy
Empty preamp tube positions.
Shows tube further back in chassis.
professormudd
Post by professormudd »
This forum has the best Dumble detectives.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
Max
Post by Max »
