Fender Twin UL transformers for Dumble?
neskor
Post by neskor »
Hi.
Can use power and output transformer from Fender Twin UL for Dumble #102 clone?
Output:
Fender 013691 - Output 135W
Output transf. for Fender Twin Reverb "Ultralinear" 1975-80, 135 Watt
4x 6L6GC 135W / 4 ohm (8 ohm CT)
Power:
Fender 013692 125P34A - Power 100W
Fender Twin Reverb 1976 sf135 Power transformer
Richard1001
Re: Fender Twin UL transformers for Dumble?
Post by Richard1001 »
Sure, just don't use the UL taps if you want a normal penthode output stage. The high voltage is probably a little higher on this power transformer but you can make up for that in your power supply.
