Heaters go where?
Oddvar R
Heaters go where?
Post by Oddvar R »
Hi. I was wondering if the heater wires go directly from the transformer to the tubes in the OD #183 build, or?
fred.violleau
Re: Heaters go where?
Post by fred.violleau »
They usually do. You need to use a transformer that provides heaters current. Does it answers your question?
Fred.
Fred.
Oddvar R
Post by Oddvar R »
Hi an thanks. The heaters would normally go to the power tube, or via the pilot light. But here there is a bit of a different arrangement?
sonicmojo
Post by sonicmojo »
It's a little circuit for the LED style DC voltage indicator light - check out the 183 schematic.
What kind of indicator light do you plan to use in your build? If you use a Fender style bayonet lamp that runs on 6V AC, you don't need that circuit at all.
Bryan
Oddvar R
Post by Oddvar R »
Hi and thanks, what kind of lamp would be used originally? I have mounted a Marshall type now, but a lamp that was original to the Dumble would be better?
norburybrook
Post by norburybrook »
It's a regular LED.
M
