Heaters for Dumble 183
Hi.  I was wondering why this layout omits the heater connections? Any hidden scheme or does it go without saying?
						Re: Heaters for Dumble 183
Hello —
I’d say something but ...
Look to photos for inspiration?
Best .. Ian
Best .. Ian
It’s just left out for clarity. As Ian suggests, have a look at photos of completed amps. Heater wires are twisted together and run about 3/4” (a couple of cm) above the socket lugs.
So, I was wondering if the old Fender twisting could be changed to the Soldano Slo wiring type?
						- pompeiisneaks
- Site Admin
You can, yes, so long as you connect up heaters, it will work. Since the dumble style layout with the heaters above and wound, is known to work well, you can stick with the tried and true, or experiement. I'm building a marshall and not twisting my heater wires as an experiment too. I may regret it
 We'll see how it comes out, but I've read a lot of people saying the wire placement is more important than the twisting, but twisting does add a bit more hum rejection.
  We'll see how it comes out, but I've read a lot of people saying the wire placement is more important than the twisting, but twisting does add a bit more hum rejection. ~Phil
tUber Nerd!
Hi and thanks for answers.  My Soldano 100w build is very silent.  Inside my Mesa Mark SOB there is also an alternative heater hookup.  I am thinking about trying this version.
Hi, there is some great info regarding other builders experiences with wiring heaters in this thread.
Hope it helps.
https://ampgarage.com/forum/viewtopic.p ... 19#p390219
Cheers
Guy
						Hope it helps.
Cheers
Guy
