BM 50 Watt Combo
dcribbs1412
BM 50 Watt Combo
Post by dcribbs1412 »
Mag Comp Marshall iron. Taylor from AN 4 pre hole silver chassis 8)
Voltages 480V plates EL34's.....might look at dropping that some, 198V on V1.
Even got the internal loop quiet :)
Maple cab with leather corners, solid and heavy
Sounds good at power up will tweak a little and roll tubes after a few days of burnin
Emi EM12 speaker needs break in also.
Last few builds have really taken a while to come together.... :(
D
fred.violleau
Re: BM 50 Watt Combo
Post by fred.violleau »
Congrats! Very Nice job, the Cab looks awesome!
Fred.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
whoa! looks beautiful, well done! I'd love to hear samples.
~Phil
tUber Nerd!
erwin_ve
Post by erwin_ve »
Beautiful looks! I dig the Maple with leather corners!
Did you have hum issues with the loop when started or was it ok right out of the box?
Synchu
Post by Synchu »
Beautiful one :)
Sound clips will be appreciated.
Niki
dcribbs1412
Thanks guys
I dig the leather corner look on the wood too, we'll see how they hold up
Loop grounds had to be moved around a little but was fairly quiet out of the box.
Will try to get clips soon, like to break amp/speaker in and roll some tubes.
drew
Post by drew »
Looks great. How does the maple cab compare, weight-wise, to plywood?
dcribbs1412
drew wrote: Fri Oct 19, 2018 4:37 pm Looks great. How does the maple cab compare, weight-wise, to plywood?
Thanks Drew
Heavier than a 1x12 combo I have in a plywood marshall style cab by a good 15-20 lbs
may be switching out the Emi EM12 its 16.5 lbs. Time will tell
D
amplifiednation
Post by amplifiednation »
Wow that looks super cool!
Amplified Nation
www.amplifiednation.com
@ampnation
dcribbs1412
Thanks Taylor
your chassis and boards made it possible
Sounding better and better by the hour
Appreciate your work.
Sent from my iPhone using Tapatalk
