Last ODS-50 build
Last ODS-50 build
I started my last ODS-50 build. Transformers used 1202-118 PT 784-139 OPT C1999 Choke
Thank you Jason for the chassis and board set.
						Re: Last ODS-50 build
Looks good! Are those 1W Beyschlag resistors?
Sent from my Moto G (4) using Tapatalk
1W Beyschlag resistors?  No 1 watt Piher's
				dcribbs1412
Looks like another great sounding build is coming!
Like to hear how you like the feel/tone with the higher 220uf PA filtering?
Also is this your first with Marshall iron and 34's?
D
D
- norburybrook
dcribbs1412 wrote: ↑Tue Mar 27, 2018 5:57 pm Looks like another great sounding build is coming!
D
I've used 220uf on both my #102 50w builds and they both sound great. I did experiment with the last one and use 100uf but in all hoensty I couldn't hear a difference so I swapped them back to the 220 as they matched the other F&T caps on the board
 M
This is my 4th ODS build with EL34's So far my favorite is a 50 watt with KT77's
Nice looking build Steve!
									Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
Nice build for sure.
The PT and OT look impressive lots of iron there.
Thank you Dr. Eric and Mark. I'm shooting for 471volts B+1 will see the JTM-45 PT in the other build achieved that voltage.
Have a great day, Steve.
				dcribbs1412
67plexi wrote:Thank you Dr. Eric and Mark. I'm shooting for 471volts B+1 will see the JTM-45 PT in the other build achieved that voltage.
Thx for the info
May try a build with Marshall iron
and more filtering
D
Sent from my iPhone using Tapatalk
Well the 1202-118 has only 446 volts B+1 no load
I think I'm loosing it after wiring up the power supply now I have 467 volts B+1 #183 was 465 volts B+1
				dcribbs1412
Looking good[emoji3]67plexi wrote:I think I'm loosing it after wiring up the power supply now I have 467 volts B+1 #183 was 465 volts B+1
Got my bias voltage adjusted 28 to 44 VDC range it's going slow. Next adjust the FET then wire the controls and so on.
				dcribbs1412
Nice work!
Builds going slower here too
D
D
