Connect VR2 from the middle potentiometer to ground OR through a resistor or ...
Help me
BUT I understood that the two tone stack for the OD was not ideal!
Also I would like to bypass the tone stack stage with a circuit that would be equivalent and adapted in impedance. The values I mentioned are probably far-fetched! I was inspired by a post from? Ontarius? (whoever makes the PHAEZ amps : I bought one, but it was not a model for me, but the construction was really exceptional !!! Real point to point, and really TOP level ! )
What do you think of this idea ? ridiculous or could it work ? What could be the circuit to make and values to choose ???
And this is the reason I need the PAB relay. ... But I understand nothing about the way they show how they connect these relay ON LAYOUT ! On a schematic, I can understand what is a Normally open or normally close position , but here HOW I have to wire my mod to this , now, free PAB relay ??? ( only a small layout could help me
A great thanks for some help for this mod IF it is POSSIBLE or another solution/idea ?
2 last questions :
1°) again my midboost is "too much" for me : too much medium : changing the cap (390p) value could be enough ? What kind of value ? ( ceramic ) ?
2°) caused by Health problem ( yes already at 65 years old
situation . I remember to have had a 15W position on my Fender 75 ( 75W) only by changing B+ and bias with a switch : could it be a good idea here OR do I have to absolutely keep this
special Bluesmaster PI and power section the cleaner possible ?
Other ideas, advices ?
Thanks for your help.
PS : there are TWO possibilities : one with the full relay, the other only with one side ( I could use this side for some tweaking on the OD, ... ) BUT with the "one side" solution, will I get hum, HF noise, ... ?
PS2: ... you have understand that English is not my mother language : so, I'm so sorry for this odd writing
