#102 Robben Ford Amp Discussion
Bombacaototal
Re: #102 Robben Ford Amp
Post by Bombacaototal »
What is the most appropriate current production pot to replace the 250k treble fender pot 021857? And what about the 500k?
Found this post with some details but no replacement source https://tubeamparchive.com/viewtopic.ph ... a044613e8a
norburybrook
Post by norburybrook »
I've always used Alpha pots. Tried Bourns , which feel better quality but the taper is weird. this should be in the discussion forum by the way.
M
Bombacaototal
norburybrook wrote: Tue Mar 07, 2017 10:11 am I've always used Alpha pots. Tried Bourns , which feel better quality but the taper is weird. this should be in the discussion forum by the way.
M
I managed to get a couple of vintage fender pots 250k #021857. Just wondering if I should use one for the Mid or not
As far as the bass pot I bought a Gibson historic series Pot 500k audio taper PPAT-059. It will be above the 400k reading tho, but hope it will work well
pompeiisneaks
Site Admin
Post by pompeiisneaks »
Moving the last few comments about the Robben Ford #102 to a discussion thread. Please post 'discussion' related things here to the "Dumble Discussion" section, and you can refer to the appropriate main thread like I"m doing:
This thread is discussion about the Amp detailed here: https://tubeamparchive.com/viewtopic.php?f=5&t=12873
tUber Nerd!
