John Mayer Dumble ODS #223
Bombacaototal
Post by Bombacaototal »
The pics are of John Mayer ODS which he was using up until "Where the Light Is". It seems an HRM with EL-34's
I found an article that lists a similar amp
https://www.premierguitar.com/articles/ ... ve_Special
I am just wondering which generation are these amps from. The article mentioned mid 90's with skyliner tonestack in a run of 40 similar amps (although the one they had was updated to bluesmaster).
For those more experienced with the sound of these amps shall we assume John's was not updated and the tonestack is something closer to a #183 then a transition skiliner from the 1988 #124 for example or a later Bluesmaster? Probably high plates?
Does anyone have more info on this ODS?
Last edited by Bombacaototal on Sat Mar 04, 2017 11:11 am, edited 2 times in total.
Bombacaototal
Re: Mayer Dumble ODS - 90's generation?
Serial was 1 apart from his back up which was #223
His main amp is either #222 or #224
#224 was a combo which was discussed here https://tubeamparchive.com/viewtopic.ph ... 3&start=15 although there is a comment it may have been converted to a head
jelle
Re: John Mayer Dumble ODS
Post by jelle »
I played a head just like it, maybe two serial numbers off. 100W EL34 HRM. I loved it. Such a sweet, mature and even sound.
Bombacaototal
jelle wrote: Tue Feb 28, 2017 4:53 pm I played a head just like it, maybe two serial numbers off. 100W EL34 HRM. I loved it. Such a sweet, mature and even sound.
Thanks for sharing Jelle
I'm thinking the circuit will be similar to either of these
https://tubeamparchive.com/viewtopic.php?f=5&t=387
https://tubeamparchive.com/viewtopic.php?f=5&t=401
Bombacaototal
An older post which seems to indicate that the low 200's had 220/150 on V1 plates
https://tubeamparchive.com/viewtopic.ph ... er#p314286
