Output transformer for dlite question
- dragonbat13
I need some help with an output transformer for my dlite build.
I am using a BN Dlite chassis. I have this power transformer:
http://www.mojotone.com/amp-parts/Trans ... ransformer
Its a bolt in for my dlite chassis. I am building my amp as a 2x6l6.
I am gathering up the remainder of the parts to finish it, I need an output transformer. I want one that will have the correct imp. taps for the chassis, 4/8/16. I know the Hammond has a funky secondary setup.
I have considered using either a prosonic OT, or a Hammond 1650N.
I was originally gonna just go with the prosonic. But then I came across the Hammond. Then I figured I may as well ask around. I am not opposed to drilling holes for a different OT footprint.
Any recommendations on which way to go?
Thanks!
Thanks!
Re: Output transformer for dlite question
I built a D'Lite for someone (complete gut and redo) some years ago. I am reasonably sure that the OT supplied was a Bassman OT. The amp sounded very good.
- dragonbat13
!!!!Colossal wrote:I built a D'Lite for someone (complete gut and redo) some years ago. I am reasonably sure that the OT supplied was a Bassman OT. The amp sounded very good.
Now ya know, I had originally wanted to use a bassman OT, but for some crazy reason I couldn't find one with 4/8/16 secondary taps. That's what had me on the hunt. I know a bassman iron works quite well for this amp.
So you post that, and I figure it would take one last look,
well low and behold:
http://www.classictone.net/40-18009.html
Well, thanks.
BTW, you got any relay boards for sale?
I have a Brownnote Dlite output that I pulled from a working amp.
interested?
interested?
- dragonbat13
Actually, I am wanting to get more headroom with some larger iron. IIRC the dlite output transformers were somewhat undersized?jelle wrote:I have a Brownnote Dlite output that I pulled from a working amp.
interested?
Is this the transformer for the 22 watt or the larger 6l6 based amp?
The Dlite had Vibrolux type PT and OT (4K & 8K)
I would use the Classictone bassman 4/8/16 OT they are good transformers or buy the one Jelle has.
Maybe Colossal has a Mercury transformer sitting around.
Actually the 18092 or 18001 would be a much better choice. It has the M6 laminate and the 18009 does not. Otherwise the specs are the same.
I used the 18092 for a couple of builds and it sounds great! One was a KT77 power amp and one was a D'MARS ODS with 5881/6L6 output tubes, which also sounds pretty good with 6V6 tubes in it.
Ha! maybe...M Fowler wrote:Maybe Colossal has a Mercury transformer sitting around.![]()
Something else to consider. I swapped a 50 watt marshall 2204 output transformer (4/8/16, 3.3K) into my brown note build and loved the way it sounded with both 5881 and el34 tubes!
Cheers
Guy
Cheers
Guy
