steel string singer Dumble schematics help?
Hallo members of the club. Im truck driver with 30jears expiriance of building "hobby" tube amps and friend of mine that is mad for guitars and amps is begging me to build him SSS Dumble clone.. I did find ODS chematics online BUT nothing over SSS Dumble oor i prefer maby more Dumble overdrive reverb.. Please help.. ps- im from Belgium and i have vacuum tubes and transfos in stock..
Re: steel string singer Dumble schematics help?
Use the search.
You have to logged into the Forum to see the Dumble Files section where there is a lot on SSS plus in the Dumble discussion section.
larsvictor
Hello jigibao, welcome to the ampgarage. It's all here, but sometimes hard to find.
You must be logged in to view and download the files.
SMS #002
https://tubeamparchive.com/download/file.php?id=23633
ODRS #013
https://tubeamparchive.com/download/file.php?id=30840
Lars
SMS #002
ODRS #013
Lars
larsvictor wrote:Hello jigibao, welcome to the ampgarage. It's all here, but sometimes hard to find.
SMS #002
ODRS #013
Lars
Thank you !! i was looking everywhere for those !!! my god.. How i can repay you for this?? kind regards
SMS #002
ODRS #013
Lars
Ok now i will start with informing you how is the progress going.. I looked today the schematics and i found for OVERDRIVE REVERB some mistakes in schematics, not a big ones but are there.. Will be cheking out soon. And for SSS Dumble schematics, hmmm i found allso some things wich are not suppose to be there, hmmm... there will be a lot of work for me as i will be building 4 guitars amplifiers .. 1 MESA BOOGIE Mark one, and 3 Dumbles " overdrive, SSS, and overdrive reverb... and everything will be dubbel checkd.. On the end of the ride i will publish the compleet tested schematics for all of you guys..
Bombacaototal
Does anyone have sound samples/videos of the original ODRS#013larsvictor wrote:Hello jigibao, welcome to the ampgarage. It's all here, but sometimes hard to find.
SMS #002
ODRS #013
Lars
Are those 510pF ceramic? Or Silver Mica?
Fantastic! It usually takes some polishing to get all the errors corrected.jigibao wrote:On the end of the ride i will publish the compleet tested schematics for all of you guys..
The fun has started.. I use donor guitars boxes from 10" and 12" fender amps for first two projects and here you can see the Japanese metal plate bender i use to make new chassis..
First chassis bend so it fits the box perfect . This one is with 10" speaker "wich will be changed for higher wattage Eminence.. Chassis i bend from 1.mm steel plate..ps-its good workout for me
. This will be copy of Dumble overdrive special.. 50watts rms is enaugh..
Second chassis build will be with 12"inch speaker. Chassis i bend for it was difficult as its tight space but i did it clean. This one is going to be copy of Mesa Boogie Mark1 with reverb. Im thinking not sure 50 oor 100watt. Now im sorry fof delays but i work a lot and dont have much free time for this.. Here are some pictures..
I have been shoping.. I bring home broken fender 212r and i will change him in something else, something better,something with vacuum tubes.. LoL..
I allso brought home 10" eminence speaker for the amp im building. Only thing i did on it is open the cone cap in middle so the high tones can come out of it...
