Small enclosure Dlator build
Started on small enclosure 12 x 8 x 2 Hammond enclosure Dumblelator using Fender stand alone reverb PT and choke.
Very early stages. :lol:
jelle
Re: Small enclosure Dlator build
Post by jelle »
Nice!! Xicon MPP caps?
jelle wrote:Nice!! Xicon MPP caps?
Yes sir.
Smokebreak
Post by Smokebreak »
Looking forward to hearing how this turns out!
Synchu
Post by Synchu »
Looks sweet.
Niki
I want to get front and back plates for this that is why I haven't gone to far yet.
Got to design them if I can. :D
10thTx
Post by 10thTx »
Mark,
I did one very similar to that years ago and it turned out really nice tone wise.
https://tubeamparchive.com/viewtopic.ph ... ght=dlator
With respect, 10thtx
I remember that build, nice to have a compact unit when rack unit isn't wanted.
My first Dlater was a rack unit so had plenty of room to play with this one will require some component placement forethought which may be challenging for me. :D
Waiting on parts for the other projects so continued today with the mini dlator.
Oh oh mistake on my face plate Recovery did not get centered my bad. :D
10thTx
Post by 10thTx »
That's turning out great! Nice job. Thanks for sharing the photos.
with respect, 10thtx
Thanks I should get to wiring it up tomorrow I hope.
Guy77
Post by Guy77 »
Hi, I also built a dlator in a 12x8x2 chassis a while ago and finally got my face-plate designed and ready to get laser etched. I attached it here if it might be useful to you. There is part of a back plate designed on this word doc as well.
Cheers!
Guy
Thanks Guy.
More wiring completed don't look too close I haven't finished wiring yet. :D
This unit was acting strange very little signal coming through so I went through all the wiring and no change.
I said to myself that I measured all the resistors before using them so I don't need to re-measure them in circuit.
Wrong I had a 100R instead of a 100k and presto the unit is now functioning as it should.
Lesson for the day check your components to save you from having to trouble shoot.
norburybrook
Post by norburybrook »
M Fowler wrote: Thu Feb 23, 2017 4:37 pm This unit was acting strange very little signal coming through so I went through all the wiring and no change.
Glad it's not just me that does that then :D had the same thing with my latest build, a 100R that was labelled in a bag of 10 from mouser as 100K.
I put my small dumbleator in the back :D
