I need the D. Overdrive Special Chassis and Cabinet measures
Kagliostro
Post by Kagliostro »
For a friend that would like to build one
I need the measures of the Dumble Overdrive Special Chassis and Cabinet
BTW which is the best thread with documentation about this amp ?
Many Thanks
K
10thTx
Re: I need the D. Overdrive Special Chassis and Cabinet measures
Post by 10thTx »
there is a useful thread here:
https://tubeamparchive.com/viewtopic.ph ... dimensions
This quote is from the thread:
The chassis I used was 19.25" x 8.25" x 2.5". Preamp board was 8" x 2.75". Power supply was 3.5" x 5". Bias/FET/Relay boards were 1.75" x 3".
and another thread is this one:
with another quote:
"martin manning" has done a very detailed layout of ODS #124 (circa 1984) chassis in the dumble files section, and I believe he was striving for historical accuracy. Those dimensions are 19.5" wide, 8" deep and 2.38" high - if this helps.
Dumble files have a lot of information.
With respect, 10thtx
Kagliostro
Many Thanks
K
So much data on Ampgarage but pain to sift through it all.
Kagliostro
Yes, as you say, a lot of documentation, but not easy to be find
Many Thanks Mark
K
