Impedance selector switch
rutledj
Post by rutledj »
Are there any specs that need to be followed (voltage or current) for a slide switch used as an speaker impedance selector switch? Will a typical 125v switch suffice (in a dumble clone)?
Thanks,
Rut
rutledj
Re: Impedance selector switch
Post by rutledj »
Maybe I should ask it another way. If I'm using ohm's law correct then sq rt of P x R = V (assuming a 50 watt amp) 50w x 8 ohms = 20v.
I = P/V = 50w / 20v = 2.5 amps. Obviously this would vary some as the speaker impedance changes but would you say I'm close on this assumption or am I way off here?
Mr. dB
Post by Mr. dB »
I suppose it would be important to know if the switch is shorting or not (break-before-make or make-before-break)?
rutledj
Post by rutledj »
Not really sure to be honest. Just a simple slide switch. More concerned about the voltage\current handling capability than what happens when you change impedance.
Mr. dB
Post by Mr. dB »
Blowing up the switch vs blowing up the amp? :)
Heisenberg
Post by Heisenberg »
Putting a slide switch in could certainly increase the possibilities of two of the secondary windings touching together. Bad news bears.
There is a very good reason you don't see slide switches on any amplifier's impedance switch. Especially in a Dumble. Break before make or otherwise.
