Has anyone ever attempted to do a control panel using Letraset dry-transfer letters?
I always wondered if that's what HAD used for some of his?
[img:900:614]http://3v6x691yvn532gp2411ezrib.wpengin ... _fg03a.jpg[/img]
Dry-transfer lettering for faceplate?
Re: Dry-transfer lettering for faceplate?
I used it on one of my dumblelators. Looks great.
But you have to use a thin layer of blanc spray paint afterwards to prevent wear on the letraset. And repeat at least 3 times.
I'd try them if they'd make a sheet from a font you upload.
Here is an example of the Amplify font that I like to use on British-style faceplates:
(Of course, you should NEVER use a fake Marshall logo, but this is just to show the font.)
[img:988:478]http://i514.photobucket.com/albums/t346 ... 20Font.jpg[/img]
Well, I ordered a couple of sheets on the Bay (HELV 72 pt and 36 pt).
I'll probably try them on a metallic silver painted chassis.
I'll post when I get some results to report on.
I have use some called Letraset about 10 years ago.
It was for a JTM45 I sprayed thin plastic sheet gold then used the dry transfer lettering. Followed by a clear coat of varnish and then put clear acrylic sheet over the top.
The biggest problem is getting the letters in a straight line, I used masking tape as a straight edge to work to then peeled it off once the lettering was in place.
Those are kind of hard to find anymore.
The letters do need a clear coat so they can't be rubbed off.
It's really hard to get the letters straight and level.
I got some years ago from my dad when he worked for the telephone company.
Also if the decals are very old they don't work very good.
