Gain staging
passfan
Gain staging
Post by passfan »
Has anyone checked the signal voltages through one of these ODS circuits. I'm getting no real output through a new build unless I start diming the stack and volumes. Voltages and bias is spot on. I'm looking for signal voltages through the gain stages.
"It Happens"
Forrest Gump
ToneMerc
Re: Gain staging
Post by ToneMerc »
passfan wrote:Has anyone checked the signal voltages through one of these ODS circuits. I'm getting no real output through a new build unless I start diming the stack and volumes.
What % taper pots are you using?
TM
passfan
Re: Gain staging
Post by passfan »
Just standard taper pots ,off the shelf. With the gain and master at 50% this thing should be loud. I'm getting up to 6 volts of signal gain from V1a. By the time I get to V1b I'm lucky to have a volt. The pi is sending 12 volts max to the grids of my power tubes with everything dimed. I'm losing signal somewhere. If I want to hear it at all at 50% I have to kick all the boost circuits on. When I get a chance I'm going to compare it to my twin.
"It Happens"
Forrest Gump
splgeo
Re: Gain staging
Post by splgeo »
check your shielded cables, problem I had
norburybrook
Re: Gain staging
Post by norburybrook »
I had exactly the same thing when I built my 100w Bluesmaste and it turned out to be a cold solder joint. Re flow the solder connections on the V1 pins.
Marcus
Re: Gain staging
Check possible shorts in the shielded cable to ground.
glasman
Re: Gain staging
Post by glasman »
Typically you will see a minimum of 35dB at around 800 hZ and 45dB+ at 1.5kHz measured on the the output coupler of V1B. Assuming all controls are centered. Treble, Middle, Bass and the "Volume" controls (30% taper). Will be less for 10-15% taper pots.
This is measured from input to V1A (grid resistor input) to the output coupler of V1B.
Gary
About 5 miles south of I-94
www.glaswerks.com
passfan
Re: Gain staging
Post by passfan »
Thanks all. Gary , just what I needed. Hopefully I will get a chance to crack back into it soon.
"It Happens"
Forrest Gump
John_P_WI
Re: Gain staging
Post by John_P_WI »
I'd suggest you investigate around the od relay and effects jacks. The wiring can be confusing to say the least. Throw a test signal and see where it is being lost
Having to dime the tone controls could also indicate a problem with the tone section and associated relays...
passfan
Re: Gain staging
Post by passfan »
Thanks John , first thing I verified as the relay cards I bought were laid out backwards and I had to draw a conversion schematic. I suspect something around the pi as I plugged into the power amp in with a preamp and couldn't get any real output. I don't think it's biased correctly for some reason and its sitting at 48 volts to the cathodes. A twin is closer to 100 volts.
"It Happens"
Forrest Gump
Re: Gain staging
Sounds like you have isolated the problem, but around 50V on the PI is reasonable. You are forgetting that a Twin has a 12AT7 PI.
splgeo
Re: Gain staging
Post by splgeo »
http://bmamps.com/Schematics/dumble/dumblenotes.pdf
alttie help with a voltage chart. PIC cathode here is around 60v. but 50v should be more the enough
passfan
Re: Gain staging
Post by passfan »
martin manning wrote:Sounds like you have isolated the problem, but around 50V on the PI is reasonable. You are forgetting that a Twin has a 12AT7 PI.
youre right.
"It Happens"
Forrest Gump
passfan
Re: Gain staging
Post by passfan »
Well after doing a comparison with my twin reverb I believe I have a bad OT right out of the box. I am driving a good 2.4 volts in both amps into the output tube grids. The twin is loud , the Dumble is barely audible. A primary winding comparison between the two shows the twin split closely between 72 ohms, and the Dumble spit at 15 versus 20 for a total of 35 ohms. I am going to do some further testing and eventually swap out the transformers before I get in touch with Webber.
"It Happens"
Forrest Gump
passfan
Re: Gain staging
Post by passfan »
Brand new OT no good. Sounds beautiful on the vintage one out of the twin. Thanks to all.
"It Happens"
Forrest Gump
