Clean channel on ODS type build easily breaks up
titser_marco
Hi guys! At what point in the clean volume's range do your builds typically break up? Using an SG with relatively hot HBs, mine breaks up at around 11. I find that this may be too early, but then this is my first ODS type build after all so would like to know your experiences. Thanks!
bluesfendermanblues
Re: Clean channel on ODS type build easily breaks up
If your volumepotmeter is liniar (1MB) a humbucker pu will overdrive slightly at 11 o'clock.....depending on pu output...a hot hb will overdrive sooner.
With a strat you can go to 2 o'clock.
However, a if you use a 30% pot, which is in between a logaritmic and a liniar pot, smilar to what dumble have used in the amps "we know" at this forum,
your knob will go a little higher before od/saturation.
