Hi!
Do I understand this right, that the Rock/Jazz switch when in Rock position will bypass the tonestack ??
Schematic "The Amp Garage  OVERDRIVE REVERB SPECIAL #13"
And it is the same on other ODS schematics.
Cheers
The SSS-Plumber
						Funktion of the Rock/Jazz switch ?
				larsvictor
Re: Funktion of the Rock/Jazz switch ?
No. The R/J switch changes the risistor/capacitor network of the tonestack. The effect is a more hifi balanced sound and a significant loss of volume when the jazz mode is engaged.
The switch (relay) that bypasses the tonestack is called "preamp boost" (PAB) and it is omited in your schematic.
Lars
Lars
Then I have a problemlarsvictor wrote:No. The R/J switch changes the risistor/capacitor network of the tonestack. The effect is a more hifi balanced sound and a significant loss of volume when the jazz mode is engaged.
Lars
				Pacosipulami
How can I help?kaj wrote:Then I have a problemlarsvictor wrote:No. The R/J switch changes the risistor/capacitor network of the tonestack. The effect is a more hifi balanced sound and a significant loss of volume when the jazz mode is engaged.
Lars
don't grow up - it's a trap!
The Dumble Overdrive Reverb doesn't have PAB it has bright, deep & Rock/Jazz.
Very nice of you to ask, on my build the tonestack seems to be bypassed when the switch is in the ROCK possition. I just have to go thru my wiering /schematic.Pacosipulami wrote:How can I help?kaj wrote:Then I have a problemlarsvictor wrote:No. The R/J switch changes the risistor/capacitor network of the tonestack. The effect is a more hifi balanced sound and a significant loss of volume when the jazz mode is engaged.
Lars
I will return when I find the fault.
Thanks fore your interrest.
Thats right, and I also have a Clean/OD switch.M Fowler wrote:The Dumble Overdrive Reverb doesn't have PAB it has bright, deep & Rock/Jazz.
Sounds like a problem with your PAB switch or relay.
