Anyone here who's built an amp based off Schematic Heaven?
titser_marco
Post by titser_marco »
Hi! Relatively new guy in the forums, so advance apologies if this question has already been asked. I was wondering if anyone had already built something based off the 70's ODS schematic on schematicheaven.com. What are your thoughts on it? Is it close enough to what people consider to be a Dumble sound?
Thanks!
rp
Re: Anyone here who's built an amp based off Schematic Heaven?
Post by rp »
Right building, wrong door, go here:
https://tubeamparchive.com/viewforum.php?f=5
titser_marco
rp wrote:Right building, wrong door, go here:
Sorry about that, but thanks!
Mods - could I ask that this thread be moved to the right forum? Thank you!
I wouldn't say this is the wrong place for a discussion about "70's" D amps, but do a search for "Second Generation."
The files section is for primarily for documents. Look there and you will find a layout under "Sticky: 2nd Generation 50w Period Correct ODS," which is close to the circuit on Schematic Heaven.
rp
Post by rp »
actually, I was directing him to the archive, web central for all things Dumble, and first place to start.
titser_marco
Thanks for the lead, Martin and RP! Will go and check that now.
