Master vol pot failure 70`s dumble
groovtubin
Post by groovtubin »
OK, just blew the master pot on 70`s circuit, grounded the tail resistor to that lug, alpha is a 1/2 watter, blowing that was FUN!! :) SO any ideas on this? I see in orig pics that HAD used older fender types, can anyone tell me if a 1 watter will handle it? :) Or should i use another ground point?
jim
ToneMerc
Re: Master vol pot failure 70`s dumble
Post by ToneMerc »
groovtubin wrote:OK, just blew the master pot on 70`s circuit, grounded the tail resistor to that lug, alpha is a 1/2 watter, blowing that was FUN!! :) SO any ideas on this? I see in orig pics that HAD used older fender types, can anyone tell me if a 1 watter will handle it? :) Or should i use another ground point?
jim
Jim, IIRC there's not much difference the wattage of those older 70's CTS full size pots and the smaller 15mm carbon CTS trimmers. No reason why the normal CTS or Alpha would not be fine, are sure it wasn't just a mechanical failure?
TM
groovtubin
jim
TM
Thanks TM! i`l try another one, if it blows i`l let ya know! Alot of current flowing! lol!
