PT for SSS
grtamp
PT for SSS
Post by grtamp »
Does the Tonemaster PT handle current enought for SSS circuit?
I found one with these characteristic:
Primary: Thermal Fuse: white/white
0V RED
120V GREEN
0V YELLOW
100V VIOLET
110V BLUE
120V BLACK
Secondary:
185V@600mA RED
0V GREEN/YELLOW
185V RED
28V@300mA BROWN
0V BROWN
6,3V@8A GREEN
0V GREEN
Smitty
Re: PT for SSS
Post by Smitty »
The back biasing is very straight forward with a full wave rectifier. I'm not sure how I would do it with a full wave bridge rectifier. You'd likely need another full wave bridge wired backwards and then drop a LOT of voltage. Kind of clunky once you start pushing the grids.
grtamp
Re: PT for SSS
Post by grtamp »
I think I will run with twin reverb iron.
Thanks Smitty
mhartman
Re: PT for SSS
Post by mhartman »
Which SSS? 100W or 150W. The 100w versions (SSS01-SSS04), as mentioned, run on Fender Twin iron.
grtamp
Re: PT for SSS
Post by grtamp »
100W !!!
grtamp
Re: PT for SSS
Post by grtamp »
...but I would build a #002 SSS
Roe
Re: PT for SSS
Post by Roe »
grtamp wrote:100W !!!
just a twin PT then
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Re: PT for SSS
Smitty
Re: PT for SSS
Post by Smitty »
It is FWB not FW like a Twin Reverb. Please see my last post.
mhartman
Re: PT for SSS
Post by mhartman »
Smitty wrote:It is FWB not FW like a Twin Reverb. Please see my last post.
Agreed. You'd probably end up having to go with a separate transformer for the bias.
tele_player
Re: PT for SSS
Post by tele_player »
The Fender Tonemaster schematic shows the bias supply is half-wave rectified from the Brown-Brown secondary, -48vdc at the tubes.
I don't know what specs he's using in the original post - but the 28vac secondary looks incorrect to me.
-robert
grtamp
Re: PT for SSS
Post by grtamp »
I think 28V brown-brown is for bias voltage doubler circuit!
Re: PT for SSS
You're both right- the Tonemaster bias supply is a half-wave voltage doubler.
tele_player
Re: PT for SSS
I'd use a doubler, if that tap is really 28v. Tonemaster schematic doesn't have a doubler, just one diode, at least the schematic I saw.
Re: PT for SSS
Yes, there are two versions- one dated '93 and the other '94. The later one uses a doubler, and the PT's have different PN's.
