D style Tweed
dcribbs1412
D style Tweed
Post by dcribbs1412 »
Sorry to add to the flood of tweed builds
the all look and sound great(the one with clips)
I was a little concerned because I kinda liked my tweed build
but decided to update it and see (had most parts on hand)
Using the older MC iron MAG-6452 PT and the MC TF-110 041318 OT
with a JJ GZ34 I had around 420 Volts
I used zeners to drop B+ 20 volts or so. Now voltages are
B+1 401
B+2 356
B+3 310
B+4 286
V1 is around 170-175 Volts
V2 is 258 and 202, 19.8 volts
10 k trimmer is at 3.6k
Not sure if Charlie is tired of hearing it but,
Thanks, I very much appreciate you sharing info about this circuit. 8)
D
Synchu
Re: D style Tweed
Post by Synchu »
I never get tired of looking at nice guitar builds and this looks great!
Tweeds are great, the more the better.
Music needs good old real sounds.
Niki
Re: D style Tweed
Nice job on your Tweedle Dee.
dorrisant
Re: D style Tweed
Post by dorrisant »
Yes, good looking build!
Any clips?
mhartman
Re: D style Tweed
Post by mhartman »
Nice! Any idea if the zeners to lower voltage have any effect on tone/feel? I might have to do the same.
67plexi
Re: D style Tweed
Post by 67plexi »
looks good like it should. How do you like the PEC pots.
Good idea on the zeners. You may want to try a matched 12AX7
in V-1.
Steve
dcribbs1412
Re: D style Tweed
Thanks guys
will try to get some sort of clips
mhartman wrote:Nice! Any idea if the zeners to lower voltage have any effect on tone/feel? I might have to do the same.
I noticed the feel of the circuit change right away, not sure the voltages
had too much affect after that. Are your voltages a little high?. I would give the zeners a try. ..Sounds like a line to sell zeners.
I did read that Jelle used a similar PT and got voltages close to the original D tweed. So some experiment with tubes may yield closer voltages without zeners.
67plexi wrote:looks good like it should. How do you like the PEC pots.
in V-1.
Steve
I am running a set of older Ken-RAD VT 107 tubes and found a
more balanced ax7 172-173V on V1. PEC pots are from previous build
they seem fine, would probably use CTS if PEC were not on hand.
Not sure I have the trimmer set right
(original has a 3.3V difference) I have 3.9-7.3(3.4V difference)
are you guys balancing voltages
or getting close and going by feel?
Probably splitting hairs just wanted any suggestions.
Darin
Re: D style Tweed
Sweet!
Nice job! :D
jelle
Re: D style Tweed
Post by jelle »
Nice build!!
Trimmer: Just go by what you hear. :D
CHIP
Re: D style Tweed
Post by CHIP »
Nice looking build. Have fun!
