Bluesmaster Clean and 124 OD question
wattsup
Post by wattsup »
Has anyone built something with the clean from the Bluesmaster and the overdrive from the 124? If so are there any sound clips or video? I've seen discussion on the other way around and was wondering what the sound would be like this way.
Re: Bluesmaster Clean and 124 OD question
Might be tough to do since some of the biggest differences between the 124 and Bluesmaster circuits are in the PI and negative feedback loop, which are common to the clean and OD.
wattsup
Post by wattsup »
Thanks Martin. I had read several posts about the 124 clean and using the Bluesmaster overdrive and was curious if anyone had ever tried the other way around.
