D Deluxe
67plexi
D Deluxe
Post by 67plexi »
Thank you Charlie for this gift. I'm down to the fuse will arrive in the mail today.
This one has a 4/8 ohm tap. I put a switch in so the heater wires are different .
May it pass the flame test.
Steve.
:D
ToneMerc
Re: D Deluxe
Post by ToneMerc »
Looks great Steve!
TM
andyhardy
Re: D Deluxe
Post by andyhardy »
Very Nice indeed!
CHIP
Re: D Deluxe
Post by CHIP »
Looking good Steve.
Just got a box from mouser today.
Planning on getting this thing done for the weekend. May be my new gigging amp.
Where do you plan on setting the 10k trimmer?
Re: D Deluxe
That should make some great tones, nice job.
67plexi
Re: D Deluxe
Post by 67plexi »
Just got the cabinet. I hope the Rocket speaker shows up today.
ToneMerc
Re: D Deluxe
Post by ToneMerc »
67plexi wrote:Just got the cabinet. I hope the Rocket speaker shows up today.
Steve in the sprit of use what you got, I have some PEG124's left over from a JTM 45/100 project that I will most likely use as well.
TM
67plexi
Re: D Deluxe
Post by 67plexi »
It's a winner only go by Charlie's hand drawn layout
the other's posted are a MESS. Other than that it's a ass kicker
With my bench test speaker. :D
Charlie Wilson
Re: D Deluxe
Post by Charlie Wilson »
Steve, that looks great! I glad the layout was useful. I suppose the 10k trimmer is set in a similar way to the ODS amps. Once I get my Low Plate Classic sorted out I may have to revisit the D Tweed.
67plexi
Re: D Deluxe
Post by 67plexi »
Thank one more time Charlie Yes the trimmer is paramount in this build.
I had V-2 pin 7 set to 26 volts sounded good when I dropped it down to 21 volts all hell broke
loose Have Mercy.
Steve,
:shock:
lovetone
Re: D Deluxe
Post by lovetone »
Sorry i'm missing something here, i can't see how you adjust the volts on V2 pin 7 from the 10K trimmer unless i'm looking at a different schematic?
Re: D Deluxe
Nice, you guys don't mess around over here 8)
Re: D Deluxe
Looks nice Steve!
Tight chassis!
67plexi
Re: D Deluxe
Post by 67plexi »
Done deal. Thanks'
Steve. 8)
lovetone
Re: D Deluxe
Post by lovetone »
Wow Steve, that looks great and built in record time.
can i ask a question i asked before?
With regards to setting the trimmer, i can't see how you adjust the volts on V2 pin 7 from the 10K trimmer unless i'm looking at a different schematic?
cheers
