"content" and "volume" on the ODS OD
mhartman
Post by mhartman »
Any circuit differences or just labeling differences?
http://youtu.be/iI3380ZRgMA
amplifiednation
Re: "content" and "volume" on the ODS OD
Post by amplifiednation »
That amp sounds awesome
Amplified Nation
www.amplifiednation.com
@ampnation
ic-racer
Post by ic-racer »
I think this shows how "content" is wired
http://img.photobucket.com/albums/v670/ ... Layout.jpg
Max
Post by Max »
mhartman wrote:Any circuit differences or just labeling differences? http://youtu.be/iI3380ZRgMA
AFAIK the OD-circuits of all the ODS amps I've played up to now are all different in detail – even if they share a general structure (pre-standard, standard, HRM, ripper etc.).
But in my perception the general function of the OD-control labelled "Content" was always the same as the general function of the OD-control labelled "Overdrive"/"Level"/"Drive".
OD-controls labelled "Content" you'll find (AFAIR what I've seen up to now) in the "gold script" transition-generation between the 4th generation and the 5th generation and in the 5th generation. See the two pictures I've attached.
Picture source:
"gold script" transition-generation from 4th to 5th: https://tubeamparchive.com/viewtopic.php?t=20316
5th generation: http://www.hugeracksinc.com/forum/viewt ... =1&t=91770 and http://personalpages.manchester.ac.uk/s ... 3169/1.jpg
Cheers
Max
mhartman
Post by mhartman »
Thanks guys. I appreciate the info!
