I've almost finished a d'lite down under (Australia
 ). i received some  custom made d'lite trannies direct from heyboer 9to fit my chassis). however the Pt has no 50v bias tap wire.
 ). i received some  custom made d'lite trannies direct from heyboer 9to fit my chassis). however the Pt has no 50v bias tap wire.Moss kindly suggested taping bias supply from the HW using the diagram attached as a guide.
It was mentioned to re-configure or make a new rectifier board, you will need the 2-3w 220K dropping resistor (in place of the 470R)
following the schematic would dictate that you change the 100uf cap to a pair of paralell connected 47uF/100v balanced with a 15K 2-3w resistor.
What are your guys thoughts on values to get -50v??
Once i get over this hurdle I should be able to get the amp up and running.
I'm not so familar with this stuff. thanks in advance.
