switching wire
switching wire
Hi, does anybody know what is the kind of wire used in the DUMBLE AMPS for the foot pedal in the switching? Thanks in advance D
						- Funkalicousgroove
Re: switching wire
It's Belden 5 conductor non-shielded instrumentation cable with a chrome jacket.  I have the P/N at home, I can't remember it.
						Re: switching wire
REALLY THANKS,what ie the right gauge?
						Re: switching wire
THANKS FUNK,where i can buy the BELDEN cable ?THANKS AGAIN
						- Funkalicousgroove
Re: switching wire
I buy it in 100 ft rolls from mouser.com  Just do a search, it's 22awg 5 conductor non-shielded with a Chrome jacket
						- glasman
Re: switching wire
Alpha (from mouser) is about the same and probably a bit cheaper.Funkalicousgroove wrote:I buy it in 100 ft rolls from mouser.com Just do a search, it's 22awg 5 conductor non-shielded with a Chrome jacket
I normally use "generic" marshall footswitches, 3 button, nice metal box, 20 foot cable and ready to slap a label on for less than $20.00.
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
Re: switching wire
I always buy USA when I can, I'm sure the Alpha is fine
						Re: switching wire
That's what I use too.glasman wrote:I normally use "generic" marshall footswitches, 3 button, nice metal box, 20 foot cable and ready to slap a label on for less than $20.00.
Gary
Re: switching wire
Can I assume that's OD, PAB, and Reverb with no re-wiring inside?  I think the mid-boost should be on a switch too.
[edit]Thanks Gary.
													[edit]Thanks Gary.
						- glasman
Re: switching wire
My pedals, no.jaysg wrote:Can I assume that's OD, PAB, and Reverb with no re-wiring inside? I think the mid-boost should be on a switch too,
I have OD, PAB and Mid Boost on the pedal.
Gary
www.glaswerks.com
www.glaswerks.com
