PT with multiple secondarys question
I'm using this PT for my Princeton/Dumble build.
http://www.classictone.net/40-18027.pdf
There are 2 secondary taps allowing either 400V or 330V output. I'd like to put a switch on the back to select either secondary for different power levels and feel.
The question is on the bias. There's no bias tap on this PT so I need to tap from one of the secondary leads. Should I tap from one of the secondaries directly, or should I switch the bias tap when I switch the secondary?
My concern is that I may not have enough range on the bias pot to handle switching secondary voltage.
Thoughts?
Thoughts?
Re: PT with multiple secondarys question
Simple solution. Use a DPDT On-On switch, the "330" leads go to one set of contacts, the "400" leads go to the other set of contacts. The center "common" contacts go to your diode string, take the bias off of both leads (keeps things balanced) before the main rectifier diode string. Use a high quality full size Carling switch. Your bias will adjust with the change in high voltage.
How about a DPDT on-off-on switch in the standby hole? Center position is standby, and the other two are high and low voltage. I agree take the bias from the center of the switch, either half- or full-wave.
Good question Martin, I try to avoid that as the bias voltage is at 0 v when switched, and IMHO the full bias voltage should be present WHEN the B+ supply is switched (as found with the "conventional" circuit position of the Standby switch.martin manning wrote:How about a DPDT on-off-on switch in the standby hole?
I'm confused, are you saying to take the bias off of both the 400V and 330V taps? Wouldn't that then connect these taps together?John_P_WI wrote:Simple solution. Use a DPDT On-On switch, the "330" leads go to one set of contacts, the "400" leads go to the other set of contacts. The center "common" contacts go to your diode string, take the bias off of both leads (keeps things balanced) before the main rectifier diode string. Use a high quality full size Carling switch. Your bias will adjust with the change in high voltage.
Um... I won't do that. No bias on standbymartin manning wrote:How about a DPDT on-off-on switch in the standby hole? Center position is standby, and the other two are high and low voltage. I agree take the bias from the center of the switch, either half- or full-wave.
Ah, very good point! Two switches are better than one, but even then as the switch is thrown the AC to the bias supply is cut.John_P_WI wrote:Good question Martin, I try to avoid that as the bias voltage is at 0 v when switched, and IMHO the full bias voltage should be present WHEN the B+ supply is switched (as found with the "conventional" circuit position of the Standby switch.martin manning wrote:How about a DPDT on-off-on switch in the standby hole?
Last edited by martin manning on Mon Dec 09, 2013 4:29 pm, edited 1 time in total.
No, the 330 / 400 v transformer wires go to the switch, from the switch center poles two wires go to the rectifier diode string. Connect the bias (dropping resistors and diodes) at the junction of the two wires and two B+ diode strings.Bob-I wrote: I'm confused, are you saying to take the bias off of both the 400V and 330V taps? Wouldn't that then connect these taps together?
Sorry if I confused you when I was proposed using both legs of the transformer for the bias, not a single (like marshall) to keep the balance on the power transformer winding.
No problem. This is what I drew up as you were replying...John_P_WI wrote: Sorry if I confused you when I was proposed using both legs of the transformer for the bias, not a single (like marshall) to keep the balance on the power transformer winding.
I'm gonna redraw... hold on
Like this?
Yes, just make sure the down stream components (pot and resistor) etc are connected otherwise the cap will see the full rectified voltage of the 330 / 400 (which ever is selected) vac windings.
Good point, I think I'll change that cap JICJohn_P_WI wrote:Yes, just make sure the down stream components (pot and resistor) etc are connected otherwise the cap will see the full rectified voltage of the 330 / 400 (which ever is selected) vac windings.
Here's the rectifier/bias board I built. Whatcha think?
I haven't seen it done before, but a voltage divider could be placed in front of the cap to protect it. This would only require adding a resistor across the cap to ground.John_P_WI wrote:Yes, just make sure the down stream components (pot and resistor) etc are connected otherwise the cap will see the full rectified voltage of the 330 / 400 (which ever is selected) vac windings.
That's a 350V cap, even if it gets hit with 400 briefly it should survive.martin manning wrote:I haven't seen it done before, but a voltage divider could be placed in front of the cap to protect it. This would only require adding a resistor across the cap to ground.John_P_WI wrote:Yes, just make sure the down stream components (pot and resistor) etc are connected otherwise the cap will see the full rectified voltage of the 330 / 400 (which ever is selected) vac windings.
