Anyone have front faceplate dimensions for D'lite chassis?
beasleybodyshop
Built a Dumble style chassis today. Anyone have the hole spacing for the front and rear holes on the faceplate/backplate? I used the search function and couldn't find any.
Re: Anyone have front faceplate dimensions for D'lite chassis?
Don't recall seeing any thing like that posted.
I only have a jpg of the faceplate.
beasleybodyshop
Thanks Mark, I think im just going to print this and use it as the hole template. Do you know if it prints to scale? I ended up making a 19X8X2.5 inch chassisM Fowler wrote:Don't recall seeing any thing like that posted.
Here is the hole layout for the CE chassis.
Not sure if the overall dimensions are what you built.
beasleybodyshop
Thanks Tom, this helps me with hole dimensions. I think Im going to measure these out and do a template. If it looks clean enough I will post it when im done - Maybe some other people could use it?Structo wrote:Here is the hole layout for the CE chassis.
Tom that would work but a Dlite is suppose to be a shorter length chassis then CE.
But I see that the OP did go 19" in length.
I have a faceplate that Shad posted in DWG format I think I could send if you have the software to convert.
beasleybodyshop
Yeah that would be great mark, I can convert it into a svg file.M Fowler wrote:Tom that would work but a Dlite is suppose to be a shorter length chassis then CE.
Dustin email sent I hope you can open they are weird file format.
Yeah as usual I missed part of the question, the D'lite bit.....
I thought I had a chassis layout for that but I can't find it.
Here is what my D'lite looks like.
beasleybodyshop
Thanks for the photo Tom, that cab/chassis looks fantastic. I think I'm going to do mine just like that.Structo wrote:Yeah as usual I missed part of the question, the D'lite bit.....
I like the Fender knobs matching the cream tolex nice one Tom.
I have a BN D'Lite chassis, if I get a chance I will notate the hole spacing front and back.
TM
TM
Thanks Mike that will help for those making a Dlite.
Here is a 19.25 version.
The Brownnote D'Lite chassis dimensions are:
Length: 17"
Width: 8"
Thickness/Height: 2.5"
Length: 17"
Width: 8"
Thanks Mark.M Fowler wrote:I like the Fender knobs matching the cream tolex nice one Tom.
I did that because with the black knobs it came with I had difficulty seeing where they were set.
