choke for DLite
choke for DLite
i'm using a westlabs set of 15watt transformers for a Dlite build (i already had them), they came with a choke, should i use it or just use the resistor. does a choke drop more or less voltage and will its tonal charactor be good or bad for this amp? thanks.
Re: choke for DLite
my suggestion...use the resistor.
